TA-2550ci random white stripes
  • redskin
    • Feb 2015
    • 6
    Hello
    I have a prob. Pls check the attached printout first, it tells everything. Drum is ok (swop them), dev "seems" ok. I checked the connectors too. Other colors are ok. No bulletin.
    Should i change the dev unit? Or something high voltage related?
    • 23002
    Re: TA-2550ci random white stripes
    If the intervals are ~38.9mm it's primary charge. You can order the MC unit separately and save yourself some money. =^..^=
    • redskin
      • Feb 2015
      • 6
      Hi
      Sorry, did you read my post?
      Random stripes and the drums has changed. It means charger isn't affected this case...
      Any idea?
      T
      • darry1322
        • Oct 2010
        • 817
        Since you say the stripes are white I'm assuming the page should be full page yellow.
        I would try a new yellow developer unit. Possible loss of transfer to belt for yellow as well. Check the contact on the belt rail for the yellow transfer roller.
          • 23002
          Originally posted by redskin
          Hi
          Any idea?
          T
          ... and the interval?
          • redskin
            • Feb 2015
            • 6
            Interval and size is random.
            I checked the belt. Nothing. I will order a new Y DV unit...
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              +1 DV unit.
              Idling colour developers are not healthy developers.
              • balengo
                • Sep 2015
                • 2
                Did you solve this issue with the new Yellow developing unit ?
                • redskin
                  • Feb 2015
                  • 6
                  Yes, that was a solution.
                  • simonsays
                    • Aug 2013
                    • 95
                    Hello
                    I myself would remove the developer units and vacuum the tops of every scanner unit toner drops on the abd causes steaks like this any where there is toner on the top glass of the scanner it causes a blank streak.
                    It always happens on the black
                    • redskin
                      • Feb 2015
                      • 6
                      You didn't read the original post carefully....
                      The streaks were perpendicular the printing direction!
                      Bye
