On a 5035 with print and scan boards our IT guy always saw a FTP selection when you pressed the scan key, we have 2 machines here that when you press scan there are only 3 selection and the 4th which is normally the FTP selection isn't there? We have flashed the machine and controller, reset the scan board through service mode, held our hands above our heads and spun around in circles(thought for sure that would do it)........... The machine See's the boards as the green lights are on and it reads the firmware version for the controller and scan card.............. What the heck are we doing wrong or missing? Oh great KM connectivity wizards please help so us Monica guys can learn!!!!!!!!!!! Thanks in advance!
KM-5035 Scan Question..... Probably simple!
Your IT guy needs to do some simple research. It needs to be setup through the web browser and server both.
Make him work for it this time, he made you run in circles.Why do they call it common sense?
If it were common, wouldn't everyone have it? -
The U-511 was the fix as it was turned off. The big question is where the heck do you find that mysterious U code its not in my service manual? Also do they have a separate manual for the print system? I need to reset the NIC and cant find the info anywhere?Comment
Great thanks for the info.............. next question, after resetting the NIC card we started getting a 640 HD failure which wasn't there before the reset, any idea?Comment
