Kyocera FS-C 2026
  • ocrumbs
    • Jul 2025
    Kyocera FS-C 2026
    We have a machine that produces copies from the MP tray with no issue but from tray 1 it pauses during the run.
    I've put 2 videos up of the issue here:
    We have changed the feed drive assembly and updated firmware but the issue still remains.
    Just wondering if anybody has ever had similar issue and managed to resolve it.
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera FS-C 2026
    This does not look like Cassette 1 vs Mp Tray issue. On the 1st vid you had some printer processing delay with the particular document. Is it EXACTLY the same configuration and document in both vids, with difference just being paper source? Is the driver latest KX 6.2?
    • NeoMatrix
      Senior Tech.
      • 3513
      Check the paper/media type is not set to thick paper. Thick paper setting is slightly slower.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1885
        More than likely the pressure spring for the pickup roller is missing. I thought I had posted the resolution to that here.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • ZOOTECH
          Senior member of CRS
          • 3375
          You probably have, but the noobies aren't doing a search before hand.
