kyocera fs-1116
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] kyocera fs-1116
    hello .we have this error message 6400 ..we show this error code sometimes ...please help .
    BEST TECHNICIAN . NICE PEOPLE .
    • 22999
    Re: kyocera fs-1116
    If you had glanced at your manual, zaza, you would have noticed that the C6400 error is a zero-cross error. You could have discovered that from any Kyocera service manual.
    A zero-cross error means that a power disruption has interfered with the machines ability to control the temperature of the fuser. You most certainly can't fix a power disruption after it's happened, but you can reset the fuser error in U163. And you could make improvements to the power provided by running a dedicated line, or connecting an uninterruptable power supply (UPS). =^..^=
    • Alexkyocera
      • Jul 2015
      • 82
      Re: kyocera fs-1116
      the C6400 is a Fuser related Error code, as "the above member": stated it has to do with your office voltage stability, please have an electrician check the voltage in your office to ensure the correct voltage input is coming in and there is proper grounding. IF that doesnt work, youll need a new fuser unit (FK-110)
