Kyocera KM3035 very light copy
  • copyTcat
    Senior Technician
    • Apr 2015
    • 58
    [Misc] Kyocera KM3035 very light copy
    Kyocera copier KM3035 was in client storage for 2 years.
    Recently trying to use the copier but getting very light copies (also when printing internal reports)
    Installed new developer unit and initialize and installed new original toner did not solve the problem.
    Please help.
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera KM3035 very light copy
    Check the transfer roller assembly. They are known to get knocked around and lose the pressure springs as well as break the holders.
    • copyTcat
      Senior Technician
      • Apr 2015
      • 58
      Checked the transfer roller and had to add the missing springs from KM5050 but still getting same issue. I also tried to install used KM5050 transfer roller but same issue. (I not sure if they interchangeable, Maybe I can test the KM3035 on KM5050???)
      • Reed
        • Feb 2011
        • 258
        How does the copy look when you stop it in the middle? Does the copy look good on the drum? Most light copies are from either bad/aftermarket toner or transfer roller.
          • 23009
          If the latent developed image looks crappy, perhaps you've got a dirty laser. These machines are certainly old enough to get dirty lasers in the right environment. =^..^=
          • Kyo fan
            • Dec 2013
            • 368
            What they said. I would just add that you should check/clean corona assembly.
            • Scottb
              • Apr 2013
              • 306
              if it has been sitting for a while I would either replace the dv unit and a new toner or at least dump the dv and use a new toner bottle.
              Oops never mind I didnt read far enough down. Yeah what the other guys said especially about the laser slip glass needing cleaned
              • copyTcat
                Senior Technician
                • Apr 2015
                • 58
                Hi guys, thanks
                It was transfer roller causing this issue
                  • 23009
                  Congratulations on your success, and thanks for posting back with your results. =^..^=
