kyocera fs-6025 mfp- cassette 1 failure
  • atech
    • Aug 2010
    • 89
    [Misc] kyocera fs-6025 mfp- cassette 1 failure
    Need help guys... machine problem- cassette 1 failure... I tried to enter to system menu>adjustment/maintenance>service settings....followed by Login username and password... I cannot complete the process to repair the cassette problem failure...The machine requires username and password...
    I need username and password. I need useful information...
    Thanks...
  • JUAN C DLS
    • Mar 2014
    • 14
    Re: kyocera fs-6025 mfp- cassette 1 failure
    Most Kyocera uses:
    user: Admin
    Passw: Admin
    Other uses:
    user: admin00
    passw: admin00
    • Kyo fan
      • Dec 2013
      • 368
      You can't fix it like that, forget about the login credentials. First pull the cassette out, and remove any stuck pieces of paper from the back of the cassette and from the inside of the machine where it connects. Power it off/on and if it still displays failure you have to initialize it. Since this machine doesn't have U906, you have to run U021, but before you do it, put a paper into the mp tray and print the event log for yourself since it will wipe it, and than run U021. After that it will display ready to copy.
      It will also wipe address book, network settings, etc. So, also before you run it make sure you know previous network settings and plug a usb drive in it and run U917, select all and export it to the usb drive. After everything is done, you will plug that usb drive in, run U917 and select import.
      • atech
        • Aug 2010
        • 89
        Originally posted by JUAN C DLS
        Most Kyocera uses:
        user: Admin
        Passw: Admin
        Other uses:
        user: admin00
        passw: admin00
        Thanks, It works... I use Admin for both username and password.
        • atech
          • Aug 2010
          • 89
          Thanks buddy for that very informative suggestions...
          • 2010mohamed
            • Oct 2017
            • 28
            how do you solve it . need help
            • 2010mohamed
              • Oct 2017
              • 28
              how did you solve it
              • JR2ALTA
                • Feb 2010
                • 2030
                Kyo Fan's advice strikes me as very wrong. Most machines like this that Do not have a 906 reset use system menu / maintenance adjustment in which you'll find reset trouble unit or something like that
                • darry1322
                  • Oct 2010
                  • 817
                  Service Menu -> Enable Repaired Unit -> Start
