Kyocera Taskalfa 820
  • KMM
    • 9
    Mentioning cassette out of order.
    where the problem lies . can anyone help
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera Taskalfa 820
    Pull out the cassette and check/remove any stuck pieces of paper. Than run U906, and after power off/on you will feel good.
      • 23010
      Most likely you've got a lift error stored as the result of those scraps of paper, or maybe the paper endstop wasn't set correctly. Follow Kyo fan's instructions. If you print off the U000 jam codes you'll find some C1010 or C1020 codes. =^..^=
