F041 Taskalfa 7551ci Taskalfa 6551ci
  • copylogic
    • Oct 2012
    • 15
    [Error Code] F041 Taskalfa 7551ci Taskalfa 6551ci
    Had an interesting error on a 7551ci recently, The machine shows F041Communication error between Main PWB and Scanner engine, oddly the power supply for the scanner ISC PWB comes from the Power Supply board used for the LCT cassettes, located at the rear of the LCT trays, rather than the main power supply board located at the rear of the image process area.( as you would assume)
    www.copylogic.co.uk
    www.photocopiersupplier.co.uk
    • 23009
    Re: F041 Taskalfa 7551ci Taskalfa 6551ci
    Thanks for sharing. =^..^=
    • ntbann
      • Jan 2012
      • 628
      Thank you copylogic! Would have chased forever if I followed the manual.
      • Danwood007
        • Feb 2013
        • 36
        Hope this saves you a bit of time one day.[ATTACH=CONFIG]30113[/ATTACH]
        Thanks for this mate. Looked at this straight away, and found the board had blew. Cheers
