C2880 Firmware
  • Glenn.ca
    • Jun 2013
    • 5
    [Misc] C2880 Firmware
    Has anyone tried to install Konica Minolta C284 firmware in muratec C2880. No firmware available from Muratec.
  • wseyller
    • Sep 2012
    • 1129
    I didn't even realize there was muratec brand version of this KM series.
    I don't know about the firmware but I would look in service mode at the current firmware it has and see if it is the same as the KM version. There should be checksum values that you could compare to see if it indeed the same exact one.
    Sent from my DROID BIONIC using Tapatalk
    • Glenn.ca
      • Jun 2013
      • 5
      Re: C2880 Firmware
      Turns out that three files were different but the KM firmware was loaded in & works fine. Still has Muratec splash screen.
      • faxgoddess
        • Apr 2012
        • 70
        Re: C2880 Firmware
        Under ordinary circumstances, the KM firmware will not work with the Muratec machines.
        Just out of curiosity, why would you want to update the firmware? This machine hasn't been out quite a year yet.
        "The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather in a lack of will."
        --Vince Lombardi
        • Glenn.ca
          • Jun 2013
          • 5
          Re: C2880 Firmware
          Copier had a lot of wierd jamming issues, firmware had 280 fixes. not available from Muratec.
          • faxgoddess
            • Apr 2012
            • 70
            Re: C2880 Firmware
            Are there any bulletins that show what was fixed on KM's site?
            --Vince Lombardi
            • Glenn.ca
              • Jun 2013
              • 5
              Re: C2880 Firmware
              Yes, If you don't have access I can send it to you (when I figure out how to)
              • faxgoddess
                • Apr 2012
                • 70
                Re: C2880 Firmware
                If you could, that would be greatly appreciated. Thanks!
                --Vince Lombardi
