OKI MPS5502 Toner Add issue
  • mansart
    • 852
    OK not much OKI experience here.....
    Machine does not recognise adding a toner cartridge. The cartridge has a chip on bottom that contacts
    corresponding "chip reader" on drum unit.
    I have cleaned all contacts, ensured proper seating of units and ensured the toner cart. is locked in place.
    Is this a common issue on this model?
    Any tips, hints or guidance greatly appreciated.
  • mansart
    • 852
    Re: OKI MPS5502 Toner Add issue
    Service manual states.......
    Confirm that the toner sensor works normally by
    using the SWITCH SCAN function of the selfdiagnostic
    mode.
    Place a white paper in front of the toner sensor,
    and check if the SCAN state changes or not
    Where oh where is this toner sensor? All I see is two contact points on toner and two on imaging unit??????
    • richs
      • Nov 2008
      • 255
      Its either the drum or toner cartridge.I have had a few calls like this.
      • dc313zd
        • Feb 2016
        • 26
        If you remove the toner cart, look on the left hand side there is a brass contact. It should have 2 tabs, are they broken or misshaped? If you remove the drum and toner together there are 2 of the sensors.
        • dc313zd
          • Feb 2016
          • 26
          • dc313zd
            • Feb 2016
            • 26
            That should be the right side, sorry.
