Hi Everyone,
I checked out the kip700m machine today and observed the machine not detecting the roll 1 media. I checked paper roll media size and type and is all correct. I switched of machine then switched on but still the same.
I removed the roll and reinserted the media correctly into the feed area. The sensor detects paper roll and pulls it in to have it set for printing but when I close the roll 1 cover the message still apperas, I tried doing a print, the machine pulls the roll some centre meters and displays Roll 1 out of media / paper.
The machine does not display any jams.
I then removed the feed sensor plus the other sensor right after the feed roller cleaned and refitted, did a test but still message persists. I also did the feed clutch and registration clutch test and all is ok. Continued on to checking other clutches and motors in the service mode and all is good.
I am still working around to get the machine fixed and ask if anyone can provide any ideas to how I can fix this fault will be much appreciated.
Thank you
Thank you
