lift for copier to replace wheel
  • MRI
    • Jun 2025
    I am looking for a lift jack to lift one corner of copier to replace wheel. I was at a company and we had one that looked like a trailer lift jack, and it would life a large copier/printer on one end to replace damage wheel. Cnay help would be appreciated.
    • 22999
    Re: lift for copier to replace wheel
    The way I would do this is to borrow the fork lift and two assistants. Set the forks to the widest width that still clears the wheels and elevate it about two feet. Your two assistants keep the machine steady, and not flattening your head while you lay under the machine. Choose assistants that you trust. =^..^=
    • MRI
      Any help -
      • NeoMatrix
        Senior Tech.
        • 3513
        ...Having never done a copier wheel change. I've taken a few off.
        I believe Formula 1 guys have it down to a few second for all 4 wheels...
        Wouldn't you luv a lift jack like the F1 pit crew use?
        Seriously though...
        Two lengths/blocks of wood with the exact height of the copy wheels, so they juuuust fit under the copier. Place the two lengths of wood under the copier and then lean the copier back against the wall. Oh! use some hold-down masking tape on the ADF so the ADF doesn't fly open and damage the ADF or the wall.
        You can lean the copier back and forward adding more padding/packing blocks of wood until you reach the top of the ceiling. It won't be that hard the leverage point is in your favor. You best get some help with adding extra blocks of wood.
        HTH
          • 22999
          Originally posted by MRI
          Any help -
          You don't like the fork lift idea? =^..^=
          • ZOOTECH
            Senior member of CRS
            • 3375
            I do, but always get the younger guys under the machine.
              • 37379
              Genie Lift, GL- 4, Heavy-Duty Aluminum Manual Lift,500 lbs Load Capacity, Lift
                • 22999
                They usually have too much common sense to stick their head under a 1000# machine, regardless of what's lifting it. =^..^=
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Found some other interesting solutions to the problem.
                  New advanced silicone inflatable device, just add saline solution to increase lift...
                  Sorry I just had to throw that one in....
