Need Some Comments and Suggestions Regarding Printers
  • goldencup
    • Nov 2008
    • 366
    Hi i would like to ask from you guys some comments or suggestions regarding printers. What models of printers can you suggest that is better or best depending on your experience with the machine. Like for example, HP or Lexmark or other brand that you can recommend. Also may i know their advantage and disadvantage like for example on pc connectivity, if they can connect on windows or mac, what parts are commonly replaced. Any ideas and suggestions would be gladly appreciated. Upon giving some ideas and models of the machine, i will do the rest of the research.
    Thank you very much.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: Need Some Comments and Suggestions Regarding Printers
    Do some research and see what models use "real" fuser rollers instead of fuser film/sleeve that HP uses. I think Ricoh still use real fuser rollers in their printers? (stay away from Ricoh copiers!)
    HP use to be the go to printer but not anymore, the new stuff is junk! The "P" series was the beginning of end for HP!
    Just my opinion but the last good printer that HP made was the LJ4350. Yes this used a fuser film but fuser lasted whole maint cycle.
      really it all depends on what the printer will be used for .... we have quite a few Oki C931e/941e unit in the field for graphic artists a.d for that do greeting cards n the such. Straight Shooter ( canada ) makes a great feeder/conveyor system for the C9xxe series production laser printer.
      • goldencup
        • Nov 2008
        • 366
        Originally posted by terramobil
        It depends on B/W or Color, paper sizes (Letter/A4 or 11x17"/A3), number of prints/month. For Letter/A4, B/W I would prefer Kyocera, but not for color.
        Thank you for your reply. what model can you recommend A3 b/w also in A3 color machines?
        • goldencup
          • Nov 2008
          • 366
          Thank you for your reply. I will do more research on that machine. how about on pc connectivity, does it have any issue?
          • goldencup
            • Nov 2008
            • 366
            Thank you for your reply.I will do research more on LJ4350. Is there any model you can recommend? also does it have any issue on pc connectivity on different operating system?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              The B&W LJ 4350 is an old printer but still being sold used or refurbed. JetDirect should be compatible with most every OS.
                HP LJ 4350 is no longer in production... some parts are difficult to find in a reliable 3rd party environment
                • Ratchet2501
                  • Mar 2017
                  • 206
                  For what it's worth Oki (brother being their closest competitor, still not anywhere near as much bang for the buck) and or well built fuser both have my vote.
                    funny because on an OKI the fuser ( on larger color model ) has a life of 200,000.... brother at best is 100,000.. and the image quality of a brother is nothing near that of Oki... not to mention the life of the drums and toners. I am ASP for Oki - Brother - HP - Xerox - Epson and KM
                    • Ratchet2501
                      • Mar 2017
                      • 206
                      I was saying that brother is cheaper, in every aspect. Some folks worship Oki.
                      Edit: A brother machine irritating a business here was the reason I sold them a Sharp machine, so I can't say I completely hate brother.
                      • goldencup
                        • Nov 2008
                        • 366
                        thank you for your reply. can you recommend a model? (A3 B/W and A3 Color).
                        • Ratchet2501
                          • Mar 2017
                          • 206
                          I haven't dealt with Oki machines much but I would recommend checking into availability of supplies. You will get good value for whatever you buy just make sure it's easy to outfit afterwards.
