OKI C9650 LED Head Replacement
  • unwork_inc
    • Nov 2016
    • 54
    It seems like one of the LED heads on my OKI C9650 got damaged so it needs to be replaced. I have a set of LED heads from another C9650 I've been using for parts, but I've never swapped the LED head. Besides being very careful when swapping them as to not scratch the black strip, are there any more complex settings I should look into (RAM reset, etc.) or just swapping them will suffice?
    Thanks in advance
    • 23008
    Re: OKI C9650 LED Head Replacement
    Just be very very careful with the ribbon cables and connectors. It self-calibrates. =^..^=
    • unwork_inc
      • Nov 2016
      • 54
      Thank you very much - I'll go ahead then and replace the damaged head
        Thanks in advance
        nope. biggest problem is getting the FCC in place without buggering up the end.
        now IF you DO bugger it up..wrap masking tape over the buggered end... take to a flatbed paper cutter ( big handled sucker ) and carefully cut the very end off
        re insert
        machine takes it from there
        • unwork_inc
          • Nov 2016
          • 54
          Thanks everyone - I was careful and didn't mess up anything when replacing the head. Printer is now working well.
            • 23008
            Congratulations on your success! =^..^=
              Congrats!
