KIP 7170 toner dusting
  • tee
    • Aug 2014
    • 79
    [CQ] KIP 7170 toner dusting
    Every week this blows toner onto the LED and charge corona.
    KIP says this model does this, I would like to fix it from toner dusting.
    Any ideas will help.
  • Flash
    • 378
    Re: KIP 7170 toner dusting
    How many prints are on the machine. It might be time for a developer unit rebuild. You can try doing the toner guide roller pressure adjustment.
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Had this problem on a 7100 and yes it will do this but usually over time and use. But I went thru all kinds of adjustments and replaced basically everything(including power supplies and wire harnesses), nothing worked.
      Short and tall of it was I eventually adjusted the biases and got it to where I would come out once every 1 to 3 months and clean it off instead of weekly. Eventually the IPS and IF card went out on the machine and after replacing the IPS, main IF harness and the IF card the problem went away.
