SC 819 code on MPC 2050 copier
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    Hi Friends I'm having MPC 2050 copier working perfectly in the past period. Now Sc 819 code appear repeatedly. Any advice greatly appreciated.
  • francisco
    • Nov 2009
    • 168
    Re: SC 819 code on MPC 2050 copier
    format HDD
      • 37532
      From Gooses Guide:
      Fatal kernel error: Reload controller firmware
      Fatal kernel error: Replace controller board
      Fatal Kernal error - Make sure the jumper on the MBU is set to on if the Fax option is installed
      Fatal kernel error: VM card option needs total of 1Gig of memory installed (2x512mb DIMMS)
      Fatal Kernal error - Update System/Copy firmware to V1.15 & ncs fw to 8.30 or higher & nib fw to 8.30 or higher
      • copier tech
        • 8174
        Could be a corrupt print job.
        Unplug the LAN & reboot if the error clears reconnect the network if error returns update the firmware.
        Has mentioned could also be a failing HDD.
          • 37532
          You might be thinking of SC 899. I had the same thought until I checked firmware history.
