C-6704* When scanning an image, compression
process from scanner
to memory is not completed
within the specified time. Evolution
from scanner to page memory
is not completed within the
specified time. SVV is not
detected within the specified
time.
Image processing board
(IPB)
I/F board (IFB)
Image memory control board
(IMCB)
Overall control board (OACB
I would suggest a firmware re-load/upgrade. A have a look at "Compression mode" for the scanner. On or off?
dljorg sent me a reply that the cero copier interface board caused the problem on 3 of his machines. I am going to try and get a new board. If anyone has a spare for sale let me know EFI p/n 45053205. Not sure about the ref in IC303 part book. I am pretty sure it is the ref #10 . Nationwide has them for about $400.
Creo is not an efi machine that I am aware of. Also re-seat the boards on the back and clean the connectors also. I had two machines that during moving and setup these came loose and caused this same issue. It still could be the interface pwb for the creo but I would try re-seating boards as that is cheaper.
I have a Cero80 (ikon c650 ikon power pro) believe it is IC303 (black case tower). You are right it is not EFI.
Yes you are right to clean it out and reseat the boards. Will reseat the machine boards and do a dusting and cleaning on the creo. Thank you for the information.
I'm getting c-6704 on a C5501 when trying to send test prints from a Fiery IC-408.
All internal prints from the engine and copies from scanner work fine.
The engine is very dusty and dirty as is the IC, so I'm going to try to clean the boards and re check all connectors and see if that works.
