Olivetti 3002MF
  • Brandon
    • Jun 2019
    • 72
    [Error Code] Olivetti 3002MF
    Good morning
    I am hoping to get some assistance here please , i am sitting with 2x Olivetti 3002MF machines both giving C2000 machine failure errors , the has just started recently and the other one we have replaced main drive and cleaned out the drum unit which helped for a short while , there is no c2000 machine failure listed in the tech manual so we using another model to try find what the error code means
    has anyone maybe had this issue before and resolved it
    thank you
  • tsbservice
    Field tech
    • 8010
    Re: Olivetti 3002MF
    Yes I also find in internet C2000 error about main motor. Did you replace it? Also check that all units like dev/drum/fuser are not binding.
    • Brandon
      • Jun 2019
      • 72
      Re: Olivetti 3002MF
      I did replace main motor and checked all units
        • 23007
        Re: Olivetti 3002MF
        I suspect this cross-references to a Kyocera ... do you know which? =^..^=
          • 23007
          Re: Olivetti 3002MF
          Is it a Matsuri? =^..^=
