KM magicolor 7450 startup fail
  • EdwinR3
    • May 2020
    • 4
    Hi,
    I have an old magicolor from the office, to work at home.
    It has kept on working for about 2 years with a warning that the transfert belt is end of life.
    After replacing the transfert belt (and the other elements included in the kit) the printer wont start up.
    The info panel is stuck at the amount of memory.
    Once after I replaced the transfert belt, I got an error message (something about the Cyan drum).
    Can somebody advice me how to make it working again (very usefull in Corona times).
    Should I replace the Cyan drum (I don't know how far in its lifecycle it is).
    I'm not a technician, but I have the service manual. It does not give any information on this.
    Edwin
  • GIUBOSS
    • 1436
    Re: KM magicolor 7450 startup fail
    Originally posted by EdwinR3
    Hi,
    Edwin
    If you are not a technician I think there is very little you can do, however try to remove the ram in the electronics part and clean the contacts by rubbing them with an eraser or simply with paper being careful not to touch the components. Also try removing and reinserting the drum units and the one you replaced.
    • EdwinR3
      • May 2020
      • 4
      • GIUBOSS
        • 1436
        The problem is old age. You tried to remove the memory that you added to see if she was the problem even if it was recognized by the machine.
        • EdwinR3
          • May 2020
          • 4
          I have tried cleaning the contacts of the memory bars, but the problem remains.
          When doing this, I noticed there is battery on the cpu unit (probably a CR2032 3Volt battery, i didn't remove it).
          Your remark of old age could be right on, regarding this battery. I searched the service manual but I dit not find any reference of this.
          Replacing it should be easy, but I wonder what information might be lost. If I need to do a system update I'll wait till someone in the know gives me some directions. Still need to search what would be needed for that and where to get the system upgrade files for this. Also will need to find an old computer with a parallel cable interface.
          Edwin
          • GIUBOSS
            • 1436
            Edwin
            I would worry before running normal boot ..., did you try removing the extra memory and putting the old parts back?
            • EdwinR3
              • May 2020
              • 4
              Yes I did.
              Replaced the bars, inversed them. All remains the same. I can't get further than the indication of the amount of available memory.
              By the sound of it the machine tries do to some callibration or cleaning, but it won't pass the memory message.
