HP CP1518ni Paper Jam in output bin
  • Rich123
    • Jul 2015
    • 35
    HP CP1518ni giving paper jam in output bin. The paper will not properly eject from output bin. The paper will stop about 1/4 inch before clearing the last rollers in output bin. You can easily pull the paper out the last 1/4 inch. Sometimes it will clear fine. I cleaned feed rollers, but did not want to remove fuser unit if there is a simpler solution. Any ideas? Thanks.
