Epson WF C5710 100016 Scanner error
  • cdvidaceiba
    • 80
    [Error Code] Epson WF C5710 100016 Scanner error
    hi got this error in some machines
    i already
    update firmware
    check scanner cable conectors
    any ideas
    thanks in advance
  • GIUBOSS
    • 1437
    Re: Epson WF C5710 100016 Scanner error
    i already
    update firmware
    any ideas
    thanks in advance
    Epson error code No. 100016
    MEANING = "HP [Home Position?] Detection Failed"
    DESCRIPTION = "- CR scanner failed to return home. 1. Damage or disengagement of the drive gear wheel train 2. Disengagement, fraying, skipping of timing belt rn- Cannot read standard / home white models 3 . FFCrn scanner disconnected, broken, tilted or damaged 4. CISrn unit failure 5. Scanner housing failure 6. Main board failure "
    try like this ower off, remove the back panel/document feeder, put it back on.
    This error appears to be a probable component overheating problem.
    Also try removing the cartridges and reinserting them
