Develop Ineo210
  • Zoren
    Technicien de copieur
    • 99
    Develop Ineo210
    Anyone, familiar with this copier. is there any similar copier to this brand/model. I just need the part# of the drum cartridge
    tnx
    Just came out from hybernation.....
  • TheOwl
    • Nov 2008
    • 1732
    I'm pretty sure that your machine is a Konica Minolta Bizhub 210. If i'm right, then the Image Unit is servicable which means that you replace the Developer, Drum and Drum blade instead of the whole unit.
    • Zoren
      • 99
      yes, they said its a konica minolta...
      i asked for the whole unit part# bcoz when the machine had a clogged toner conveyance, i had to tear the drum unit apart its kinda annoying putting it together.. its not a quick fix and i really dont like small copiers like this...
      • montana
        • Aug 2008
        • 393
        that is right.it is compatible to konica minolta 161-162-163
        toner&drum+blades are the same type
        • TheOwl
          • Nov 2008
          • 1732
          These units are easy to service and probably take no longer than 20 - 30 mins to completely rebuild.
