Paper feed shaft has a broken pin that formerly was attached to the paper feed gear. Gear is now free wheeling on paper feed shaft. Unknown if individual parts available or just assemblies. Either will do. Any idea where these may be obtained? Thanks for any consideration.
Epson ET-5170 rear paper feed/rear door assembly
Re: Epson ET-5170 rear paper feed/rear door assembly
I may be able to suggest a MacGuyver if you take a few photos. =^..^=If you'd like a serious answer to your request:
