olivetti d-Color 2554MF
  • brantekcc
    • Jan 2022
    • 45
    [Electrical] olivetti d-Color 2554MF
    Good day all
    I am hoping i can get some help here please
    i have a Olivetti d-Color 2554MF that is arching between the high voltage transfer board and the back cover behind it as in image attached
    does anyone maybe have any ideas for me as to what the cause could be please ?
  • techsxge
    • Jan 2022
    • 660
    Re: olivetti d-Color 2554MF
    2554MF is quite old... If you apply even the lowest pressure, every material will eventually bend a bit.
    Unless you've got an Error coming from this, i'd not worry about it that much and if it does produce an error i'd switch out the MFP. Its just too old by now
    • tsbservice
      Field tech
      • 8031
      Originally posted by brantekcc
      [ATTACH=CONFIG]55247[/ATTACH]
      Good day all
      This is looking quite dangerous. I wouldn't recommend working on this machine without changing HVT board and/or trace cables.
        • 23010
        I don't know if this would help ... maybe?
        There was a machine (sorry, can't remember what brand/model) ...
        Oh, wait, I remember now! It was the Toshiba Alabama LSU board. When you removed the laser the LSU board would contact the engine frame and short out the board. As these machines got older, it got more and more necessary to remove & clean the laser.
        Anyway ... to prevent the PWB from shorting out to the frame, before I re-installed the LSU I would adhere a thick sheet of mylar (report cover) to prevent accidental electrical contact with the frame. If you look around in your copier graveyard, you'll probably find a machine in which the board is backed by a translucent plasticy insulating sheet. Use that ... use two-sided tape to stick it to the metal frame.
        There have been other machines that if you pressed the underside of the scanner, it would short out the component pins on the scanner PWB. Same fix.
        Just a thought ... =^..^=
        • techsxge
          • Jan 2022
          • 660
          oh shit oh dear lord forget my answer. Google Translate did a very very bad thing and translated the word "arching" in a completely different meaning... And i thought the blue light was maybe your flashlight...
          Yeah, unplug the machine and thorw it away. If i look at this, it feels like the machine is burned down already. I would not risk the 100 of errors coming soon...
