OKI Microline 395 Help!!!
  • Wild Bill
    • Jul 2005
    • 774
    [Misc] OKI Microline 395 Help!!!
    Only while printing checks it turns itself offline "Select" Then customer can press select and it will print 1 line then turns itself off. When it does this it has the alarm light on. Worked fine for me on wide format paper. Checks are 8 1/2" form paper. Never saw it. they couldnt print checks because of security. Im waiting till they run a big job. This is a good customer of mine just helpin them on this not too knowledgeable on these.
    Any help is appreciated, TY!
    Izzy
    • 22999
    I don't know if I'm going to be much help. I've worked on exactly two of these. The first one had a worn out the print head. This customer was a municipality that used it exclusively for printing tractor feed, pre-perforated cardboard, post card sized, pre-printed water bills. Initially, our salesman had sold them a used Sharp AR-M237N, promising that it could feed their tractor feed, pre-perforated, postcard sided, pre-printed water bills from the paper tray. You can image what I went through trying to make that happen. So the dealership I was at sold them the exact same Oki dot matrix printer to replace it. I fiddled with the settings for days, trying to get it right. It would print one water bill, then wait. The thing was, I could only test it on the customers obsolete, DOS based software on the only computer that still worked, in their office.
    Finally, I got the idea that I'd put the good print head into the old printer, print off the settings, then blindly copy the settings into the new printer.
    Honestly, I have no idea which one of the many settings made the difference, but in the end, we were printing water bills again. Several things were different. I may have saved that settings page. I'll check back if I can find it. =^..^=
    • Eric1968
      • 2458
      I think the lever on the right side is set to the wrong paper path (rear feed / top feed).
