OKI 8800 - Service Code 150
  • SAFC73
    • Oct 2008
    • 12
    [Error Code] OKI 8800 - Service Code 150
    Hi ,
    Can anyone help have no experience with OKI - code 150 which Im led to believe is drum life error on Yellow unit (Fuse??)
    Have swapped drum unit to no avail - any suggestions any chance of service and parts manuals
    Many Thanks
    SAFC73
  • JustManuals
    • Jan 2006
    • 9838
    This Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
      • 23010
      Originally posted by SAFC73
      Hi ,
      Many Thanks
      SAFC73
      It has to be a new unit to reset the error. Swapping in a used unit will not help you. There is usually a fuse on the unit that resets the error, and is simultaneously blown. Sometimes you can get to that fuse, and install a good fuse. Sometimes you can't. =^..^=
      • SAFC73
        • Oct 2008
        • 12
        Hi blackcat have tried a new unit still no go - any ideas???
        • Eric1968
          • 2458
          Could also be a bad connection between the drum/ID-unit ant the PRT-board. The manual says something about a bad connection or replacing the PRT-board.
          • SAFC73
            • Oct 2008
            • 12
            Thanks for your help eric will give that a go - Glad Ricohs aren't this much hassle !!!!!!!
            • djandl
              Colorado Copier Solutions
              • May 2010
              • 19
              Drum Fuse cut NG, Color:Yellow
              When yellow drum fuse-cut error has been detected at power-up
              Seek attention of service person if restarting the printer does not correct the problem
              This is from a Okidata website error code guide
              http://coloradocopiersolutions.com
              info@coloradocopiersolutions.com
