Check for invisible laser emissions?
  • mrwho
    Major Asshole!
    • 4299
    [Electrical] Check for invisible laser emissions?
    Anyone knows of any way of checking if a laser unit is emiting (short of looking directly at it and see if I go blind or not), to troubleshoot white printouts?
    Cheers!
    Mascan42
    Ibid
  • mrwho
    Major Asshole!
    • 4299
    Solved!
    Followed these instructions here on a old webcam (luckily I had a couple just like the one pictured) and it works a charm!
    Mascan42
    Ibid
    • mike*
      • Jun 2010
      • 58
      so with the old web cam it would pick up on the laser since it was in infrared mode?
      • mrwho
        Major Asshole!
        • 4299
        Either you have a camera that can pickup infrared (some camcorders can when in nightvision) or you can modify a webcam using the method above (which is what I did).
        Mascan42
        Ibid
        • Eric1968
          • 2458
          If the laser isn't emitting, you would instantly get a Service Call.
          • Morlock49
            • Mar 2009
            • 166
            I don't know if it will work with laser, but I use the camera on my mobile phone to check Document size sensors are working in the scanner unit. apparently the camara can "See" a wider range of the light spectrum, so maybe it can see into the infra-red.
            Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
            • Dave10
              • Jul 2008
              • 197
              For a relatively low cost, you can obtain a small card with a reflective surface on it that you can hold in front of an infrared laser and if it is working, it will show a spot on the surface. If you need it often enough, it's worth the investment. It's fun, too.
              • mrwho
                Major Asshole!
                • 4299
                Well, that has an advantage of not needing the laptop. But since I carry mine to all the customers, the camera I used cost me 10€ - or about $13 at current rates.
                Mascan42
                Ibid
                • mrwho
                  Major Asshole!
                  • 4299
                  But I found out that the laser is emitting but it isn't drawing the printout on the drum (I posted a video here).
                  Mascan42
                  Ibid
                    • 22999
                    I've heard about this from one of my Kyocera class instructors. My phone doesn't have a camera, but he demonstrated with several cameras in he class. It definitely works. =^..^=
                    • mrwho
                      Major Asshole!
                      • 4299
                      I tried with two phones and neither could catch the laser beam. But I'll try it with the original sensors when I return from vacation. With normal paper passage sensors, sometimes you can see a faint red light with your naked eyes, so I assume the original sensors are similar, and maybe the phone cameras can see them better.
                      Mascan42
                      Ibid
