DELL 1320C
  • auburn business systems
    owner/technican
    • Mar 2009
    • 46
    [Error Code] DELL 1320C
    This printer has a 007-371 error code. Have the xerox manual for it but that code is not in it (or i can't find it) any help on this thanks howard
    • 23009
    What's the cross reference?
    I'm glad to see that you made it here, Howard. =^..^=
      owner/technican
      • Mar 2009
      • 46
      xerox machine is phaser 6125/6130 but can't find the error in it howard
      • JustManuals
        • Jan 2006
        • 9838
        Why would you think a dell code would be in a Xerox manual?
        • TMTFL
          Becuase several of the Dell Color printers use the Xerox engine.
          • mrizer
            • Mar 2009
            • 70
            Dell actually uses the same diagnostic sequences and error codes as the corresponding Fuji/Xerox engine, which I believe is a DocuPrint C1100. Although this is also a Xerox 6130/6140 machine, US Xerox decided to use a different error code scheme. I can't tell you for sure, but I believe it is a drive/motor failure.
            Michael Rizer
            Free Technical Support
            Item Inc. 800-367-4836
            mrizer@iteminc.com
