oki 9600 prints one color only
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Customer called... c9600 printer printed only cyan . reinitialized printer & all colors printed. Later disassembled to clean printer & now only prints yellow. Strange huh? Still can print in black though......
    • 23010
    Have you printed off an error report to see if any errors were recorded?
    • Eric1968
      • 2458
      The rear side of the LED-Heads are connected to ground when you close the top cover. When this contact is bad, the LED-Head is not connected to ground. Maybe the metal clips at the rear side of the LED-Heads are bend or dirty.
      • blazebusiness
        • 1257
        Thanks - I'll check out those connections
        • blazebusiness
          • 1257
          I'll also print the error log & get back to you Blackcat-thanks
