admin password
  • jseguin
    admin password
    Does anyone know if the web interface's default admin password for an Imagistics IM3511? We have one and no one seems to recall it.
    Thanks.
    Jeff
  • sleclerc
    The default password for my im4510 is "1234". It's probably the same for your model.
    • civic066
      Admin pw Imagistics
      I have several imagistics IM3510/4510 printers that i cannot access via the web interface. Login Admin and pw 1234 or 00000 do not work. Our local support recomended that the Nic be reset. That did not work. Any suggestions?
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        user: admin password: admin
        • jmc
          IM3511 Admin password
          I'm having a similar problem myself. A long time ago, the Admin password was changed on our im3511 and no one remembers what it was set to. Is there a way to reset it without wiping the entire printer?
          • adam555
            No one has any idea????
            I have a similar situation. I'd be willing to wipe the entire printer, but there's nothing in the manual that tells you how.
            • RSFarrer
              • Sep 2008
              • 20
              go to the admin area, under the network/printer area, do a "factory reset" and it'll go back to the admin as username, password = 1234
              • drummerbiker
                Re: admin password
                I just tried 12345678 for the administrator logon on my OCE CM2520 and it let me in!!!!
                  • 22997
                  Re: admin password
                  That's because your Oce' CM2520 is a rebadged Konica Minolta, not a rebadged Sharp. =.^..^=
                  • drummerbiker
                    Re: admin password
                    That's irrelevant to me as long as I'm able to login as administrator and perform the tasks required. But thanks anyway (?)
