FS1010 Printer Prescribe command
  • bill0934
    • Aug 2025
    I am installing a second tray on a FS1010 and looking for the prescribe command line to set the second tray (T2) for a 8 1/2 x 14 paper size
    Does any one remember this command? and how do I install the command
    on a network printer?
  • JustManuals
    • Jan 2006
    • 9838
    Kyocera-Mita - products new home -
    $11.77 and instant download.
      • 23010
      The paper size for a universal tray can be specified for a specific print job, but that isn't the way to set the paper size default for an optional tray. You'll want to open your browser, enter the IP address of the printer into the address line then Enter. Now you'll see the Command Center (aka the printers webpage). Select the Printer tab, then the paper source link. From the next screen you'll be able to select a specific paper size for the optional tray, then Submit to lock in the setting. =^..^=
      • bill0934
        I checked but there is no Printer Tab or paper source link on
        the Kyocera mita FS1010 printer webpage
          • 23010
          I haven't worked on the FS-1010, but every other Kyocera printer Command Center that I work on is laid out the same. Are you accessing the Command Center? Is there a login/password set up to block your access? If yes, you'll need to get that login/password from the administrator. No, I don't know what the login/password would be. =^..^=
