KonicaMinolta BizC550 Fax forward to folder/email
  • MFPTech
    • 486
    Hi,
    I have been reading C550 manuals and cannot find if Fax Forwarding to a folder or email address is possible on this model.
    I also like to forward fax reports /journals to an email address.
    Your help is much appreciated!
    Thanks in advance,
  • Meach
    • Nov 2008
    • 128
    It is listed in detail in the C550 User's Guide FK-502 Fax Operations.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      to forward to a folder/email is possible just need the destination set as a one touch.
      As to the fax reports I am not sure of that.
      • MFPTech
        • 486
        Do you mind elaborating on the one touch please?
        Thanks!
        • Mr Spock
          • Aug 2006
          • 2064
          Go to the following link and search for the users guides. These will explain everything.
          Service & Support | Konica Minolta Business Solutions, U.S.A., Inc.
          office systems in first box
          scroll down to bizhub c550 in second box
          user guides in the third box
          Then get the admin guide, user guide, and fax guide. This will help you.
          • pdcopiers
            • Jun 2014
            • 15
            Re: KonicaMinolta BizC550 Fax forward to folder/email
            Hi Guys, I have a problem with a Bizhub c353 to forwarding faxes to a folder. I already a folder and the process to do this is:
            1. login in to admin. mode (Password 12345678)
            2. fax settings
            3. function setting
            4. rx data operation
            5. forward tx setting (turn on)
            But I don't know why in my client machine is not appears forward tx setting.
            Appreciate any tips on this problem.
            Thank You
            • MFPTech
              • 486
              Check Step 4 - you are looking to forward TX settings, not rx.
              • TheOwl
                • Nov 2008
                • 1732
                Forward TX Settings is the correct function you are looking for when trying to forward incoming faxes to a folder or email destination.
                The best way to set this up is to create a One-Touch destination which you can then try sending a scan through to make sure that the details are correct. You can then use the following from the machine (sorry, I can only remember off the top of my head for the machine and not the web interface):
                1. Utility
                2. Administrator Settings
                3. Fax Settings
                4. Function Settings
                5. Forward TX Settings
                6. Enable
                7. Select from Address Book
                8. Select the One-Touch
                9. Ok and Close once finished
                • pdcopiers
                  • Jun 2014
                  • 15
                  Hi guys, I went yesterday to my client to try to forwarding faxes to a folder. I followed all the instructions, I go to service mode:
                  1. Utility
                  3. Fax Settings
                  But I stop here because the machine don't show Forward TX Settings (It's missing)
                  I don't if I missed something on the configuration, but I never had this problem before.
                  Thank You for your help.
                  • TheOwl
                    • Nov 2008
                    • 1732
                    Sounds to me that you may need to initialize the fax and make sure that the correct regional settings for the fax are set.
                    Go and find a copy of the installation guide for the fax kit which has the steps for initializing the card.
                    • pdcopiers
                      • Jun 2014
                      • 15
                      OK I'll do that, thank you so much. I have to go back to my costumer this week and I'll let you know.
                      • pdcopiers
                        • Jun 2014
                        • 15
                        I got the machine to forward faxes in to a folder. Thank You so much for all your help, I'm really appreciate.
                        1. Utility
                        3. Fax Settings
                        6. Enable
