Imagistics DL46
    • 23009
    Imagistics DL46
    Anyone ever heard of an Imagistics DL46? This yellowed dinosaur comes with a complimentary "C0996". Is this a Pitney Bowes or a Xerox? I've never seen one of these beasts before.
  • Copier_Guy
    • 543
    I've never seen one, but I believe that unit is a Pitney Bowes Mail sorting reject.
    Let's hope it doesn't go postal on you.
    Good Luck
    P.S. That complimentary remark is a nice touch. Keep up the good work.
      • 23009
      It's made by Oce', that much I could find out.
      • vstar
        • Aug 2007
        • 176
        DL-46?
        Are you sure that it isn't a DL-460? If so it is made by Minolta and if I remember your code is the large paper try on the bottom of the machine.
        Clean all sensors very good, they get alot of dust in them. Be sure to take off the front cover of that tray to get to them. If this does'nt fix it try the ribbon cable on the back of the tray.
        When I worked for them I had to do this all the time at a school district I took care of.
        Hope this helps.
        Cameron
          • 23009
          Thanks for the reply. Too late now. I have no regrets seeing this one go to the dumpster.
