OKIDATA c550/980 Error code,?OKI TECHS CAN ^YOU PLEASE HELP
  • cucuklotz
    • Mar 2007
    • 611
    HI,
    Should a jam (first one in fuser) set off code on new fuser unit.SURELY there must be some way to reset 980 code other than replace fuser,This unit has less than 50 copies on it.are there any adjustments that Ineed to do on machine ?PLEASE HELP.
    THANK YOU,
    ANDY
  • JustManuals
    • Jan 2006
    • 9838
    Re: OKIDATA c550/980 Error code,?OKI TECHS CAN ^YOU PLEASE HELP
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Just put in a new fuser and claim the faulty one.
      • cucuklotz
        • Mar 2007
        • 611
        HI,
        Thanks for reply. My only concern is <Is there possibly another issue causing fusers to blow?
        THANKS ANDY
        • Eric1968
          • 2458
          Possible causes for defective fusers on this model :
          - Bad or broken thermistors (Fatal Error 170-177
          - Fatal error 928, Fusing unit does not rotate properly.
          • cucuklotz
            • Mar 2007
            • 611
            Hi Eric.
            Thanks SORRY I KEEP DOING THIS IT IS A C5500,CAN I chane themistor on new unit I have in machine?
            Unit has 50 coipes.I just put in machine new.
            ANDY
            • Eric1968
              • 2458
              You can't order separate parts for the Fusing Unit. You'll have to replace the whole unit.
              Here in Holland we can claim a defective supply. If I have a defective Fusing Unit that has done, for example 2k, I can claim the defective unit.
              Regards.
              • NSD
                • Aug 2011
                • 44
                Put the machine in Fuse Keep mode then you can test with a brand new fuser without blowing the fuse in it.
                • cucuklotz
                  • Mar 2007
                  • 611
                  HI,
                  Thanks for tip.Fuser didnt blow until 2 days later,However Ill try your suggestion. Im not that familiar withy machine. Can you tell me how to put in safe mode?or do I need to porder manual from Paul to do this,
                  Thanks Andy
                  • NSD
                    • Aug 2011
                    • 44
                    send me a private message and we can sort out a manual for you in the morning
