OKI MACHINE--error code 560 (machine model c9650)
  • leuwcharly
    • Sep 2011
    • 9
    [Error Code] OKI MACHINE--error code 560 (machine model c9650)
    machine is showing error code 560!.solution?....then this machine when i replaced the whole set of drum with new ones: C,M,K accepted but Y refused. When we take the same Y drum
    and put in the other machine(same) the drum is working perfectly.what could be the problem??solution please urgent.
    Then another machine the same model....when i close the front door cover,the machine is still displaying the message<the cover is not closed,close the cover>...i checked the door sensor but all in vain....if your experience with these machines please give possible solution.. thank
  • leuwcharly
    • Sep 2011
    • 9
    Re: OKI MACHINE--error code 560 (machine model c9650)
    The top cover is not recognized, when you
    close it, there is a message saying: PLEASE CLOSE THE TOP COVER since
    the cover is closed!
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • richs
        • Nov 2008
        • 261
        If you press the help key and it displays a error 310 the driver board in the back has a fuse blown.There is an OkiDoc on this problem.
        • leuwcharly
          • Sep 2011
          • 9
          where can i get oki DOC?
          • leuwcharly
            • Sep 2011
            • 9
            Does documentation on the drivers CD of help?
            • pLatik
              • 169
              Symptom:
              The operator panel displays "Close Cover Top Cover" and "Error Code: 310" when the Help button is pressed.
              Cause:
              The 310 error can be caused by the fuse F506 on the motor driver board, (S2M).
              When this fuse F506 is open, the operator panel will display "Close Cover Top Cover" and "Error Code: 310".
              Resolution:
              Once it has been confirmed that the fuse 506 is open you should replace the motor driver board, (S2M), part # 42868111.
              • leuwcharly
                • Sep 2011
                • 9
                okay i will check on that but how do i access the motor drive board and how do i notice its open...i have never opened this machine neither do i have parts manual...where can i get parts manual of this machine an how to access this part?...please advice its agent.
