1232 magenta image error
  • diego_akd2009
    • May 2011
    • 79
    [CQ] 1232 magenta image error
    Hi, I have this printer, this failure alone makes the color magenta, on the back side of the impression, it seems sewr contact failure, but did not see much this model of machine, thanks
  • diego_akd2009
    • May 2011
    • 79
    Re: 1232 magenta image error
    is in a ricoh 1232c, thanks
    • Eric1968
      • 2458
      Replace the Magenta DV-Unit.
      • diego_akd2009
        • May 2011
        • 79
        thanks eric, but replaced him and not the dev-mag, the printer stopped working and the problem is between the dev and the transfer belt.
        • Eric1968
          • 2458
          Could also be a defective development clutch.
          • diego_akd2009
            • May 2011
            • 79
            Was solved by changing the transfer roller right door, as it was not only in the magenta but in all colors, thanks!
