Oki C9650 Dirty edge
  • inkey20
    • Aug 2025
    I am having a problem with dirty edges of toner (mainly black) on the edge (control panel side) of the paper. I have replaced the toner/ drum/belt and fuser but no difference. If you print a 30% tint on both edges of a sheet of paper, the edge with the dirty marks prints more like 80% as though it is distributing the toner unevenly.
    Any suggestions welcome (it happens on all types of paper worse on a silk finish)
    Thanks in advance
  • Eric1968
    • 2458
    Re: Oki C9650 Dirty edge
    Maybe the paper is causing this. These printers can handle a lot of different sorts of paper, but sometimes the paper isn't suitable for printing on this machine. Did you specify the paper weight or is the printer measuring the weight?
    • inkey20
      It happens on all papers and boards coated and uncoated. Tried various paper weight settings as well as automatic The silk is a digital silk paper.
      • Eric1968
        • 2458
        You can also change LED-Heads and see if the problem shifts to another color.
        • inkey20
          I'll give that a try and come back with the results, thanks
          • inkey20
            Tried changing LED head on black with magenta head no difference in marking. It does not mark when I set it to Transparency setting but then it has an overall mottley background tint.
            • Eric1968
              • 2458
              Can you post a scan of the problem?
              • inkey20
                Scan attached of fault
                • Eric1968
                  • 2458
                  You've replaced drum/toner/belt/fuser and no result. The only thing I can think of is the High Voltage Board (beneath the transfer belt).
                  • mjarbar
                    Did you change just the transfer belt or the whole thansfer unit? I have had a problem similar to this that turned out to be the transfer roller.
