Oce TDS 400 Scanner installing Problem
  • mindhunter
    • May 2008
    • 148
    Hi Every Body .
    I bought A new Oce TDS 400 Black And White Plotter.
    I Search And Finally I could Install Printer On Windows XP Via Fiery . But Whatever I searched I Couldnt Possible Way For Installing Scanner . Please SomeOne Guide me .
    Thanks . Mindhunter
  • mindhunter
    • May 2008
    • 148
    Re: Oce TDS 400 Scanner installing Problem
    Originally posted by mindhunter
    Hi Every Body .
    Thanks . Mindhunter
    is there any help ?
    • riabreuer
      • Hemlock
        • 432
        Once you select your language, it populates with links to the appropriate documents.
        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
        • mindhunter
          • May 2008
          • 148
          my problem is on my scanner I cant select file. when I press File Button . Nothing Happens And still Copy Led Is On.
          • Hemlock
            • 432
            Not sure what to tell you, other than read the manual & try to work the issue yourself or call your local Oce' dealer. Oce's aren't as prevalent as other copier brands, so the likelihood of finding someone that can help you out is kinda slim. Not trying to be a jerk, just trying to explain what you're up against.
            • mindhunter
              • May 2008
              • 148
              you know on my controller i have to enable scan to file . but I dont have this Option On my controller and I found out its usuall. My controller version is : 2.1.9.0 . is there Any possible way to install this option on Controller ?
              thanks.
