trouble code C-1183
Oce CM4251
Tags: None
Re: Oce CM4251
... hmmmm. The last time I saw that code, I had powered up a machine with finisher and the finisher tray was not yet installed. I had to remove the finisher top cover, manually drive the finisher tray down about 25mm, then attach the finisher tray. =^..^=If you'd like a serious answer to your request:
