OKI 3640 (again)
  • Synaux
    • Mar 2012
    • 1224
    OKI 3640 (again)
    Okay, this is partially in reference to this post, but a different set of questions that I cannot seem find any answers for.
    After getting error code 616 Incompatible Toner, I have attempted everything I can thing besides EEPROM reset(s). I can access the Maintenance Menu, but I cannot access any of the following (second picture is FYI):
    As a result, I installed the Fiery controller into a known working machine, and got the same Incompatible Toner (616) error.
    I have tried resetting the CMOS; however, there does not appear to be any real factory default setting in the documentation that I have other than the EEPROM resets that I seemingly cannot access.
    Other than resets, I do not have any other options available other than a firmware reload that seem realistic to me (but with no firmware software available).
    There is one other thought, I might be able to switch the BYN chip/board (but I do not think that is the issue, and the documentation quite murky).
    Any direction is much appreciated.
    You can contact me at synauxcc@gmail.com too.
    --Nick
