Wierd issue with RISO HC 5500 - Need Help
  • Oktobernv
    • Mar 2009
    • 38
    [Misc] Wierd issue with RISO HC 5500 - Need Help
    Greetings All.
    I just bought a used Riso HC 5500. Mainly for printing envelopes.
    Machine seems to be in GREAT shape.
    However, I am getting a "random" issue that is occurring when printing envelopes.
    The printed envelopes will pick up random "stains" of ink. All color, and in different places each time.
    If I just run "flat" 8.5 x 11 paper through the machine, it seems fine.
    It seems that the "thickness" of the paper or the envelopes is what is causing the problem to appear.
    See attached photos for samples of the problem.
    Thanks in advance for any help or tips on solving this.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Wierd issue with RISO HC 5500 - Need Help
    this is a typical issue with riso machines.
    try running them with the flaps tucked inside and see if that works.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Oktobernv
      • Mar 2009
      • 38
      Thanks for the tip!
      I'll give that a shot
      What is the reason that this causes Riso machines a problem?
      Rob
      • Oktobernv
        • Mar 2009
        • 38
        Tried running with "flaps" tucked in....
        No better
        Still getting random ink "stains"
        Any other thoughts?
        Thx much
        Rob
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Shadow
            • Sep 2011
            • 455
            your going to have to contact your local Riso technician, as there are adjustments that may have to be done.
            you say this is a used machine, why was it removed from the previous owner's place.
            something may be worn and need replacing.
            • SteveF
              Field Service Manager
              • Jul 2012
              • 49
              hello Oktobernv
              is the m/c set to thick paper or envelopes ? this is set in system settings ...this setting should help
              • Oktobernv
                • Mar 2009
                • 38
                Hi Steve and thanks for the reply
                What does "the m/c" refer to?
                I am new to this machine so any more specific info would be greatly appreciated.
                Thank you kindly,
                Rob.
                • SteveF
                  • Jul 2012
                  • 49
                  sorry m/c is short for machine
                  if you selct menu on the machine screen you should be able to scroll down to configuration section their it should say standard tray (paper type)
                  change it to envelope or card stock and see if that helps ...you will need to select envelopes on the print driver aswell
                  hope this helps
                  menu then scroll to 4 press ok.then go to 1 press ok then go to 1 ..this should get u to the place you want
                  • Oktobernv
                    • Mar 2009
                    • 38
                    Steve
                    Thank you SO MUCH for the help.
                    I followed your direction and this seems to have solved the problem!!!
                    Only a short sample size so far, but looks good.
                    Cheers Man!
                    Much appreciated
                    Rob
                    • SteveF
                      • Jul 2012
                      • 49
                      Glad i could help Rob
