What Vacuum Do People Use?
  • Mooseface2r
    • Jan 2011
    • 114
    As above. im getting fed up with the noise/lack of power from my 3M. is there an alternative?
    • 23010
    Re: What Vacuum Do People Use?
    It's the only kind I've ever had, and as long as you keep the filter clean the 3M is adequate. Not wonderful, but adequate.
    If you're doing B&W only, the Type 2 filter will give you a little more suction. For color the Type 1 is a must. =^..^=
    • sdrawkcab
      Confused & Bewildered
      • Jun 2009
      • 317
      I want to be the first to say........
      My vacuum sucks.
      Some days, it's just not worth chewing through the restraints
      • doug94550
        • Dec 2011
        • 138
        Personally, I have not used a vacuum cleaner for over 15 years. The way I heard it is that the tip of a vacuum will typically generate 3k to 5k static voltage. This can jump to a ground up to a foot away and take out sensors along the way and cause all kinds of "Well it wasn't doing that before you came here" problems.
        For me, rags are just fine.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Originally posted by vtech
          You might want to consider the Atrix Omega Supreme Vacuum. The most powerful and quiet service vacuum!
          • THE OMEGA SUPREME PLUS IS THE QUIETEST, MOST POWERFUL SERVICE VACUUM AVAILABLE.
          • THE NEW MOTOR USES LESS ENERGY THAN STANDARD SERVICE VACUUMS.
          • THE OMEGA SUPREME PLUS IS MADE FROM HIGH-IMPACT STAREX FLAME RETARDENT ABS POLYMER FOR DURABILITY.
          • IT COMES COMPLETE WITH ALL ACCESSORIES DISPLAYED ABOVE.
          • IT ALSO FEATURES OVER-HEAT PROTECTION AND FIELD REPLACEABLE LATCHES.
          Refer to the attachment brochure for more..
          Order from our online store at or call (604)589-7194.
          Cheers,
          Vendmark Technology
          "the right way to clean equipment"
          this is what I use and what I give my techs. very quiet, great power !!!!
          Mystic Crystal Revelations
