HP 4250 13.98.00 Paper Jam
  • djfenti
    • Nov 2012
    • 20
    [Jamming] HP 4250 13.98.00 Paper Jam
    Getting a13.98.00 Non Specific Paper Jam followed by a 13.06.00 Fuser Output, Paper Stopped Jam. Anyone have a clue on what may be causing the issue?? Thank you in advance for taking your time to answer.
  • Flash
    • 378
    Re: HP 4250 13.98.00 Paper Jam
    Check the paper feed solenoid on the right side. The foam pad wears out exposing the adhesive and causes the solenoid to stick.
    • draph
      • 132
      Remove the back cover and watch the fuser film rotate during warm up. If it slows down or stalls remove the sleeve, clean up the old brown grease and apply new. I've had this several times. Mostly on the 4015's.
        • 22930
        I'll confirm that. Be sure to use the correct fixing film grease. =^..^=
        • Wild Bill
          • Jul 2005
          • 774
          I know this is an old thread but this video may help someone
          Izzy
