Kip 6000 Wide format
  • copyman
    Owner / Technician
    • Sep 2005
    • 4745
    Just bought this 6000. It is clean with 200k on meter. It has the 2050 scanner & 200 stacker table. It passed good test pages so I offered a ridiculously low price and they took it.
    My Kip experience has been mostly with the 3000/3100. Copier tech for 35 yrs.
    Anyway have a few issues / questions.
    1)
    After I got it back to the shop I cleaned inside and changed wires. Pages looked great 36 x 48. I changed test mode to 30 inch length not to waste paper, when trying to run 36 x 30 machine stops with E-07 cutter error. OK with 48" length. Even though I didn't think it was a bad cutter (cuts fine) I took it out of machine, blew out, bent the hm pos switches to make better contact. Weird thing is when it stops 30" sheet is halfway through fuser with trailing edge just off the sensor in middle of transport bed, then about 8" piece just cut and laying in middle then about 12" being feed into machine. Any ideas what this could be?
    2)
    When using roll #1 paper keeps backing out of feed in slot, and roll has slack and unwinded? Roll #2 works fine
    3)
    Machine also had a tower & keyboard. I'm assuming this is for scanning or like a server? Can someone explain the deal with printing & scanning with this machine?
    Thanks for the help
