Kip 7100m
    • 23009
    Kip 7100m
    I'm hoping someone here can steer me in the right direction. I've got a Kip 7100m with the two roll feeder that does not recognize the paper. The screen says "Roll 1 Not Found", "Roll 2 Not Found." It still holds the correct paper information size and type.
    In service mode I was able to see the paper sensors PH6 and PH7 change state from low to high when paper is present. I can also hear the feed clutch click in service mode. So I have some confidence that the modular drawer connector is not damaged or insulated with paper. Naturally I looked too. I've already replaced the main PWB, no change. I can see that the drawer is being provided with four 24.1vdc lines. I'm fairly sure that the drive is being provided by the main body, and I can see it turning.
    What am I missing? =^..^=
  • jdzr
    • 125
    Re: Kip 7100m
    Well it looks like you are not going to get a lot of help on this one. I am not real familiar with this model of KIP but check out this website for KIP info. It is a bulletin board website like copytec but for KIP and other brands. Real good info and I have used it for years on KIP & Xerox
    KeepItPrinting.com :: Index
      • 23009
      Re: Kip 7100m
      Funny you should mention it. I got a PM from another member with the same information. It looks handy ... but does not address the "Roll 1: Not Found" situation. Now I've got two machines, a 7100 and a 700 that both have the same problem, the same day.
      When it rains, it pours. =^..^=
