Oki 5502 advice : RUN
  • JR2ALTA
    • Feb 2010
    • 2033
    and don't look back
    • 23010
    Re: Oki 5502 advice : RUN
    There has got to be a story behind this. =^..^=
    • pacman
      I can turn a screw...
      • 318
      We have a few of these out there. We haven't had any issues whatsoever other than one that was defective out of the box. SO FAR it's been set em and forget em.
      • bryand
        • Jul 2008
        • 92
        We sell the Toshiba variant, we have several where the slit glass gets deep scratches in it and you have to replace the whole scanner bed at a cost of $600.00 and it takes hours to replace. Also who's bright idea was it to cause the machine to stop operating when a part reaches its life expectancy??
          • 23010
          We also have the Toshiba rebadges. Like most other Oki's the color is richly saturated, the consumables are expensive, and it was never really designed to be taken apart. Who's brilliant idea was it for the scanner to tip over on it's side, and to be balanced on those two slender pillars?
          The consumables are very easy to change, if you can get your keyop to try it. =^..^=
