Zebra P330i card printer with broken frame
  • KJEpps
    • Jun 2012
    • 63
    I'd love to get my hands on the service manual for this, but even if noone here has one, maybe you can provide some advice.
    A post snapped off of the plastic frame, so initially I thought it would be unrepairable. I did some searching and I can purchase the Center Frame (p/n 105912G-658). However, without the manual, I don't know if there what adjustments and calibrations may be required to move everything over to this new frame. I don't really want to open up a new can of worms trying to do this. Is it possible that Zebra has a retrofit kit to repair this?
    Any help would be greatly appreciated.
    • 23010
    Re: Zebra P330i card printer with broken frame
    If you can disassemble right down to that small section of frame, I think I would take a shot at superglue to keep it in position, then smearing up the outer part with two-part epoxy. Let it cure completely for at least 24 hours before re-assembling.
    I've had success with some of the small tabletop Brother machines when the posts have busted off. You'll have a total of perhaps 30 minutes into it, so not a great loss if it doesn't hold.
    If you try it, let's see the pictures. =^..^=
    • KJEpps
      • Jun 2012
      • 63
      Have you tried this on this particular model before? That post holds a bracket that the ribbon tension spring is attached to, so there is some pretty significant force being applied to it.
      (I found a refurbished printer that I'm selling them, so I don't see myself trying this, but thanks for the feedback!)
        • 23010
        Originally posted by KJEpps
        Have you tried this on this particular model before? ...
        No, just a general observation. =^..^=
