about panasanic DP 8016
  • raztech
    • Dec 2008
    • 88
    Dear
    my copier Panasonic DP 8016 shows key without any incacations..
    may you help me about please.
    regards
  • onetek
    • 318
    Re: about panasanic DP 8016
    Get into F8-06 mode to check for error codes. Also check your counters, it could be a 85k maintenance reminder....
    • raztech
      • Dec 2008
      • 88
      thanks v.much. I will try to do it
      thanks again
      • subaro
        • Oct 2010
        • 1274
        Originally posted by raztech
        Dear
        regards
        Is it showing key or a wrench symbol. If is the wrench, then as onetek says, it usually a pm item. If the machine is working fine then go in service mode F7 and change drum count, pm count and dev to 0. Also i would set F5-70 To 0 so as to not to pm. With these machines, let it run till the customer call for service and check the machine and see what needs replacing.
