Panasonic kv -s7065c jamming issues
  • alliedofficeproducts
    • Jan 2015
    • 92
    Happy thanksgiving everyone. Got a 7065c scanner jamming at the bite of the entrance into the feed rollers on the adf. I replaced the tension spring that is above the upper feed rollers because it was broken and replaced the feed roller kit. It seemed to take care of the problem at first but started back after a few hundred scans. There are no scanner error codes to use for troubleshooting other than there is a paper jam. It feeds maybe 1/4 inch. Almost like it's too tight or too much pressure. Any ideas at all would be greatly appreciated at this point.
