Suddenly can't print anymore on Panasonic DP-8016 from windows 10
  • Casian55
    • Jul 2019
    • 18
    [Misc] Suddenly can't print anymore on Panasonic DP-8016 from windows 10
    Hi everyone, I have 2 Panasonic Workio DP-8016 connected via LAN to 2 windows 10 v. 1903 computers . Since last week everything has been working fine. Now I can't print anymore on them.
    No configuration has been changed. I've already tried an USB configuration, also changed port type from RPT to Standard TCP/IP and other printer settings but I can't figure out what's going on..
    Could it be related to a windows 10 compatibility problem? Maybe after updates this old printer is not supported anymore..
    Any help will be appreciated.
  • FrohnB
    • Jul 2017
    • 1919
    Re: Suddenly can't print anymore on Panasonic DP-8016 from windows 10
    This thread may help - Windows Update Has blocked print cabability!
    Recent Windows update has affected printing.
    Are you using a PCL5 driver?
    Omertà
      there have been several threads started on this subject.
      yes it is a win10 issue.
      • copier tech
        • 8132
        I see MS have addressed this issue today.
        • Casian55
          • Jul 2019
          • 18
          Solved! You're right, here I found the updates that I needed: Microsoft Update Catalog
          Everything works after updating. this issue seems related only to 1903 and 1909 june updates.
          • copier tech
            • 8132
            Great thanks for the update.
            I went straight to the Win 10 download page got the latest release, installed "The Windows 10 May 2020 Update 2004" & now my MP C305 I was using a test printer on a PCL5 driver prints OK (before this update it would restart the pint spooler!)
            Download Windows 10
